    Jun 2006
    i have a trance cd 2 disc cd and when i try to burn the cd disc one it wount fit on to one disc because all the files together r to big the disc could hold 79:59:71 and the disc is 80::22:46 how could i make the songs fit on one cd? also im useing toast 7 to burn the files.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    You could use some of the lead-out space for music data if you overburn, which Toast won't do. Find another burning app for this project (Dragon Burn, MissingMediaBurner).
    Dec 2003
    Eugene, Oregon
    Alternatively you need to edit out about 30 seconds. CD Spin Doctor (bundled with Toast) can trim off the start or end of tracks.
    Jun 2006
    i got Dragon Burn and payed for it and im trying to use it so i went to overburn in preferences and and changed it but it did not work it tells me Not Enough Space In Destination when i try to bun the cd
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Both the cd-r(w) writer drive and the burn software have to support overburn for it to work, iirc. Try googling your drive model + overburn to search for other user's experiences. I can't help you with using Dragon Burn, as I'm not familiar with it.
    Apr 2005
    Blacksburg, VA USA
    The best I've ever gotton onto an 80-min audio
    CD is about 74 minutes. You need to go without
    a couple tracks.
    Al Bloom
    I leave about 60 seconds free (79 minutes max, in other words) and never have an issue. While the discs are marketed as "80 minute", there are a few MBs used for housekeeping, etc. so you really never get the full 80 minutes.
    You might, however, try eliminating gaps between songs (which would save about 2 seconds per track). The suggestion to edit out some of the start/end of the tracks is also sound; perhaps there's a long fade-in or fade-out that you may find acceptable to cut out.
    Let us know what happens.
