Hi,
I have converted some files from a DVD RAM disk and reauthored onto a DVD-R disc using TMPGenc DVD Author. I even setup a menu with this program with 4 chapters. When I insert into my DVD player it plays right away the first chapter. Why is it not going to the chapter menu first? I can get to the chapter menu by hitting the root menu button on my remote. Any ideas on how to fix this would be much appreciated
Thanks, Martin![]()
what did you set the "First play" to?
what version of tmpgenc dvd author? -
Hi,
it is version 1.5.20.62 of TMPGEnc DVD Author. Just found the problem. Had it defaulting to play all tracks instead of Display Main Menu as the Firstplay action. Thanks for pointing me in the right direction.
Thanks,
Martin -
I had this bug in v.1.5 (changing first play settings didn't work, menu was only accessible with remote) and not in 1.6.
fast forwarding authored DVD causes sync problem
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 00:10 -
Samsung BP3600 problem playing Nero authored DVD's
By stonejg in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Jan 2010, 12:56 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
How to change highlight delay in authored menu?
By gsh in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2009, 10:09 -
how to recompile customs menu to authored dvd?
By nick101181 in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2007, 17:11
