So far I've tried:
- XMPEG
- AVI.Net
- AutoGK
XMPEG gave a crappy result, and I can't install all the components of avi.NET and AutoGK (don't ask why). SimpleDivX gives a superb result, but there's a bug with detecting the correct length of the actual movie, which makes the file larger or smaller than the goal.
- SimpleDivx
Until the bug in SimpleDivX gets fixed: is there a program out there I haven't tried?
Results 1 to 11 of 11
what exactly happen when you try install autogk or avi.net or fairuse wizard? any error msg? they all work fine om my winxp sp2.
I just tried FairUse Wizard again, and it gave me a pretty good result, but I think it can get better?
I don't know how to set up the XviD codec (1st and 2nd pass) could you post your settings? -
I managed to install AutoGK on another computer, but I don't think that it's better than other programs. See for yourself.
AutoGK
FairUse Wizard
DVDFab Platinum
If I scale the original movie to the same as the ripped, then it's pretty close, but if I go full screen, the quality drops a lot, compared to other rips that I've seen.
Any comments on the quality? -
acutally to me AutoGK looks the best.. look at the knuckle on the thumb there.. in all three images.. DVDFab has "blocks" on the skin of the hand then it improves w/ Fairuse but it's still present and w/ AutoGK it's barely noticible that there's any blockiness. I personally use VituralDubMod to encode my Xvid files and I only run them on a Single Pass w/ the Profile set to DXN HT NTSC bitrate varies though. I also extract the wav out of the dvd and encode it to a 48000Hz 128Bit MP3 then i mix the audio and video after compression of each by doing a Direct Stream Copy and saving as an AVI.
DVD Authoring with best passthrough options
By outlawstar223 in forum Authoring (DVD)Replies: 10Last Post: 9th Nov 2010, 12:07 -
Check Over My Options From DVD to XviD Conversion Thread
By adalect in forum Newbie / General discussionsReplies: 4Last Post: 9th Feb 2010, 20:24 -
DVD Burning software options
By BarnabasB in forum Newbie / General discussionsReplies: 15Last Post: 9th Jun 2008, 13:50 -
DVD Menu Options
By BritGuy79 in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2008, 16:47 -
tape to dvd am I using the better options
By pantsdavies in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:32
