how do I break the avi file into 2 part, so I can put them on 2 cdr. I am using super dvd creator to convert the avi file. When I selected the file, it said exceeding the dics media limite size, can not burn to one dics. what should I do and what program do I need to break it into 2 parts
I've never heard of that program you're using, but I would suggest that if it doesn't allow you to manually set bitrates or alternatively have some sort of blanket "fit to 1 disc" mode then you're probably better off chucking it and trying something like Convertxtodvd. Or you could learn how to do things the manual way - see http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm for more info on this.
If in doubt, Google it. -
SUper DVD Creator only creates DVDs, VCDs and SVCDs. VCD has a limit of 74 minutes on a 650MB CD and 80 minutes on a 700MB CD. SVCD will fit about half that running time on the same size disc. DVD is the only format that will allow you to put it on a single disc.
You need to read the help files that came with it to work out how to tell it what size disc you are using so it splits automatically. I suspect at the moment it thinks you are targeting a DVD blank, which is big enough for it not to have to split.
It doesn't give me much confidence in a product when they put things like this in their FAQ
And people bitch about the black bars on 2.35:1 material !The resolution of DVD film is 720x80(NTSC)or720x76(PAL)Read my blog here.
16:9 .avi file doesnt fit the analog TV
By rekotc in forum Newbie / General discussionsReplies: 15Last Post: 1st May 2012, 14:01 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
I can't play a big avi file
By Xp4nd3r in forum Newbie / General discussionsReplies: 6Last Post: 20th Feb 2009, 07:29 -
.AVI file too big for utube - how do I get there?
By jaug in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 19:58
