I used windows movie maker to make a simple slide show and copied it to CD-R & a CD-RW.
The DVD player is a Proton PD800 which is supposed to play both formats but player says it is wrong type of disk. I contacted Protron but the tech could only tell me about getting a "zone 1" disk and to try it. I bought both Sony disks in USA as well as the DVD player. I would appreciate any help.
thanks
Results 1 to 10 of 10
What format did you use to burn the slide show? It is most likely burned in a format the player does not support.
Google is your Friend -
Thanks for the quick reply..
I tried to copy using movie maker's default, which is a "best choice" and I also tried
"Video for local playback (2.1 mbps NTSC)" -
Movie Maker creates WMV files. Those are not playable on most (any?) DVD players.
You are going to have to convert it somehow. Check out all the tutorials at : http://www.windowsmoviemakers.net/Tutorials/Index.aspx -
Wow! Thanks for the tutorial site. I'll look at the tutorial in the meantime but, I was hoping to get some quick information (if possible) on getting this to work as I need to do a presentation with it.
thanks -
Read this post:
https://forum.videohelp.com/viewtopic.php?p=1620240#1620240
Similar thing, except you would encode the DV_AVI to MPEG2 (and Audio to ac3/mp2/pcm) and author for DVD...
Scott -
Scott,
In your post you mention "Load into timeline. Export as DV-AVI (type1)"
Not sure what you mean by <export> ?
Also, which file to use: TMPGEnc-0.11.20.97.zip or TMPGEnc-2.524.63.181-Free.zip
thanks -
It's in one of my previous posts on the subject, but a synopsis goes like this:
WMM-- [File | SaveMovieFile | "My Computer"] [Next] ["myname", "mypath"] [Next] [Other Settings : DV-AVI (NTSC/PAL)]
(IOW, I meant "save" the movie file)
RE: which TMPGEnc,
The latter is probably more robust.
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 13:44 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
how can i make sure my dvd will work in any player?
By el_nex in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2009, 17:22 -
Cannot figure out which dvd player will work.
By capman21 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Mar 2008, 10:04 -
How do I get my Region 2 (from France) DVD player to work in US?
By squintycat in forum Newbie / General discussionsReplies: 10Last Post: 17th Oct 2007, 23:00
