Hi,
I've tried to convert an DivX-file to MPG1 in TMPGEnc. After 11:24, it stops with the message "Illegal floating decimal point calculation order."
Does anybody know what that means? It's the only file where that happens, other files work perfectly.
Thanks, Basileus
have you tried converted to audio to a separate wav and encode http://www.vcdhelp.com/virtualdubaudio.htm ?
http://www.vcdhelp.com/tmpgenc.htm#problems -
No, but I've found the article just after I posted my question. Will try and post, if it worked.
Thanks.
Basileus -
I am having the very same problem i have tied to use virtua dub and reencode and get the very same message. I am open for any suggestions.
I rebuilded the index of my avi-file with DivFix and it worked!
Got a few artefacts at the corrupted frame, but what the heck...
Basileus
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 14:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
