Hello,
I've authored a DVD in DVD-lab Pro, everything working nicely, BUT in "Zoom Player" as well as on standalone DVD Player the label/name of the subtitle(s) does not appear! In 'Zoom Player' I get "Unknown", on my standalone "---" shows instead of label.* PowerDVD shows the label...
I have tried IfoEdit (loading the respective VTS...X.ifo) as well as PGCEdit, and although they update and the DVD's playing fine in every other respect, the subtitle STILL does not show it's label...
Any suggestions? Did I accidentally omit any other location in the DVD structure? I've looked up all those guides on Ifoedit and PgcEdit, but they do not describe this problem.
* The subs themselves play and show up nicely, but not their language label...
Hi-
I've never had your particular problem, but when I want to add the language label I open the DVD in PGCEdit, I right-click the video in the left window and hit Domain Streams Attributes. In the new Streams Attributes window that opens up, I assign the language. If that doesn't fix it, then I don't know. -
Thanks for the quick answer!!
Am still at a loss what to do or what I might have forgotten... I assign the sub-stream's attributes in DVD-lab in the proper location (sub-window, as well as Movie-window), still no go...
The audio-labels are correct, only the sub-label isn't.
Thanks, guys, for your kind help!
Well, it is a PAL-movie, so I don't think, that the NDF-option would change things for the better. But here is another thought: how would the NDF help in the display of the subtitle's label?
I WILL try the update though, perhabs that takes care of this problem. I'll keep you posted!
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 06:03 -
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 07:21 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 08:56 -
DVD Lab message: No subtitle stream normal?
By stantheman1976 in forum Authoring (DVD)Replies: 1Last Post: 21st Feb 2008, 11:10 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 20:41
