With the "use pulldown" box checked by default, I have noticed that with a vcd/mpeg1 file in ntsc film format (23.98 fps), svcd2dvd does not actually apply puldown and convert to ntsc 29.97 fps, and the resulting log file shows at "creating DVD folders" continuous lines of "frame rate not dvd spec 1". With an avi it always converts ok.
Is the "use pulldown" setting only for use with AVIs ?
It only works when SVCD2DVD needs to re-encode. i.e mpegs going from pal to ntsc or hdtv or avis.
Does the dvd play ok? If not the mpegs will need to reencoded to ntsc before they are loaded into SVCD2DVD.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks ChrissyBoy, all understood.
The DVD does play ok in my standalone, I was worried that it might not in others.
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 17:53 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34 -
A question about pulldown
By Talayero in forum DVD RippingReplies: 8Last Post: 7th Sep 2007, 13:37 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 07:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 04:25
