i have a new macbook pro with the intel core duo. i was wondering if anyone knows any programs i can use to copy dvds to dvdr's on my mac. on my old laptop i had dvdshrink, dvd decrypter and nero. help is much appreciated. thank yu
Probably better answered in our Mac Forum. Moving you.
And welcome to our forums. -
MacTheRipper for ripping and DVD2oneX for compression and burning.
I use MTR 3.0 ( beta need to donate to get it)and DVD2oneX 2.1.0 plus Toast 7 sometimes.
If you want MTR 3.0 go HERE to donate to get the beta version.
DVD2oneX is try before you buy so give it a try. DOWNLOAD HERE -
Yes perfect response. Have used MacTheRipper and Toast Titanium for burning without any problems whatsoever.
Those are indeed great suggestions. Since you also have the capability of dual-booting, you have the option of continuing to use your pc tools in addition. Depending on whether the source dvd has errors or was authored a bit off-spec, different tools may or may not balk at doing the job, so it's nice to have alternatives.
Problems copying CDs on Mac
By Nilfennasion in forum MacReplies: 3Last Post: 3rd Jul 2009, 08:15 -
copying to dvds
By kopkid in forum MacReplies: 3Last Post: 17th Feb 2009, 09:49 -
Help with copying DVDs. Thanks very much.
By seymoria in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jan 2009, 12:06 -
copying analog 8mm to mac using sony digital 8 and firewire
By iampammyb in forum MacReplies: 4Last Post: 15th Nov 2008, 00:15 -
Best DVD to DVDR Copying Software
By mattstan in forum DVD RippingReplies: 1Last Post: 18th Aug 2007, 09:24
