'C:Windows\System32' should be fine for standard DShow filters but the filters i found on the web, i think they were 'Celtic Druid' compiles were found in a directory labeled '64-bit'. Do those still go in the System32 directory or should they be placed in, and registered in, the 'C:\Windows\SysWOW' dirtectory?
What's the new rule?
64-bit DLLs go in system32
32-bit DLLs go in the WOW one.John Miller -
So the new directory is for the emulated portions of the OS? I had things reversed then. I thought that the system32 directory was just as it sounded, and the new directory was for 64-bit stuff.32-bit DLLs go in the WOW one
You'd think that Microsoft would name the directory system64.
This does explain why the 'WnAspi32.dll' was completely ignored in the 'system32' directory, and why the current dshow filters, visible through the Radlight Filter Manager, were inside the sysWOW directory.
Thank You.
It's still called System32 because it makes it a lot easier for developers to port their 32-bit code to 64-bit.
John Miller
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Stream DShow Error Messages on WinTV 1600
By SufferingHere in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2009, 16:00 -
using videos starts dshow over and over
By radman202 in forum Newbie / General discussionsReplies: 5Last Post: 29th Jan 2008, 11:49 -
multiple instances of dshow being activated
By radman202 in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2008, 10:50 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
