  1. I have some old backups that I made on 2 disks. Anyone know how I can make them into 1 disk? Thanks.
  2. Thanks for the reply. Let me explain. I backed up 1 movie on 2 disks now I want to convert the 2 disk movie to 1 disk. They both have some of the same file names so I can't put them in the same folder.
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    Just use DVD Shrink, it's very easy.
    He's a liar and a murderer, and I say that with all due respect.
  4. Each disk has "Title 1" and the same ".vob and vts's. Will this cause problems?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Nope.
    See https://www.videohelp.com/guides.php?guideid=538#538 or https://www.videohelp.com/guides.php?guideid=378#378 for the general idea.
    If in doubt, Google it.
  6. Member rvelez's Avatar
    Oct 2005
    This is what you want"
    http://web.archive.org/web/20060515075320/www.ifoedit.com/joinclip.html
    At the moment the site is a little slow.
  7. Member Super Warrior's Avatar
    DVD Remake Pro. Awesome program, can join 2 discs to 1, with menus to each intact.
