I sent my JVC DR-M100S in for repair a few weeks ago because it would not recognize any DVD discs, bought or blank. The machine returned yesterday and seems to work fine now. I'd really like to know what was wrong with it for future possible repairs, but the invoice that came with the machine is not very specific. I was wondering if anybody on this forum with more experience with JVC machines and/or repairs had any idea what some these part numbers and abbreviated descriptions meant?:
There are two parts that were apparently supplied:
1. Part No: QAL0704-M100KIT; Description: DVD unit
2. Part No: LPA10289-01C; Description: Digi.Pwb Assy
They marked in the Customer Complaint field: Unit in warning mode, loading shows in display, read letter!!! (not very accurate per the description I sent in, but if they understand it...)
Then in the "service performed" area it says:
Electrical part
Unit parts
P.W. board assy
I know this is a little technical, and maybe nobody knows the answer to this info.But I figured I'd post about it and maybe if someone out there has a similar DR-M100 problem in the future, this may help them figure out the error. Looking forward to seeing if anyone has any insight! Thanks.
Results 1 to 9 of 9
I just checked J&R Part Search and found nothing. Those must be "units"....like complete circuit boards.
QAL0704-M100KIT - replace dvd unit (lens , motorized load unit) + control circuit (1 piece assembly)
LPA10289-01C - Power board assembly
The unit bellied up , and the circuits were partially fried due the electronic failure ... this is why the unit appeared to still function , but would not touch any disc's ... make sure it's on an appropriate power board .
Lucky your's was under warrantee .
You'll find those numbers on the replacement components inside the unit . -
It's really good I sent it in then!
This was a machine that was hardly overworked. I bought it in December 2005 and it did not see too much use (although when I did use it to transfer tapes, I was very happy with the quality it provided).
This does not bode well for the quality of JVC parts, if much of the apparatus had to be replaced! I wonder how long it will last now.
Thanks for the "translation"
JVC parts are no better or worse than any other DVD recorder. Its a commodity world. Everyone has cost reduced. Direct byproduct is too much heat which leads to component failure.
Product differences today are primarily software/firmware - no difference in manufacturing cost. -
That pretty much sums it up!Originally Posted by oldandinthe way
Yes agreed. Except with JVC they fail more often because of poor design. The design was so poor that JVC now relies on LG to manufacture their DVD recorders.Originally Posted by lordsmurf
What they replaced is not enough to say if there is a parts or application problem. Service center technicians are taught to replace entire assemblies to save time. This is particularly true of assemblies with surface mount parts which are very difficult to remove and replace.
They usually start with an assembly they suspect and replace boards until the unit works. It may not even have been necessary to replace both assemblies. These units typically only have five assemblies ( front panel, power supply, main board, digital board, and the dvd drive ). -
Maybe that is why the repairs do not last long. They replace one failed poorly engineered board with another poorly engineered board.
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 555Last Post: 1st Jul 2013, 12:33 -
JVC KY-19U with BR-422U test and/or repair
By rgabby1966 in forum Newbie / General discussionsReplies: 0Last Post: 26th Sep 2009, 01:17 -
JVC 'loading' repair details
By Jack Africa in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Apr 2009, 02:19 -
interpretation, I try to copy it because I enter the translation again
By krrish in forum Authoring (DVD)Replies: 3Last Post: 9th Sep 2008, 15:14 -
QUestion about JVC HR-S7600 repair...
By fireballtp in forum RestorationReplies: 5Last Post: 19th Nov 2007, 02:12
