I want to pull a single chapter of a dvd and put it on a new one but when I extract with DVD decryptor and then put the m2v and ac3 into dvdlab it says, "This file is corrupted because it doesn't start with the correct file header. DVDlab fixes it but removes 384 bytes of data from the AC3 stream.
Then it says the m2v stream is corupted and fixes it by removing 98 bytes of data. Then DVDlab warns me that open GOPs are detected in the file. After compiling my new dvd I find that the video and audio are out of synch.
I can fix this with the audio synch tool in tmpg but it is time consuming. Is there a way I can rip a single chapter without the audio getting out of synch?
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together.
VideoRedo does an excellent job.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Vobedit ... open first vob of title ... hit demux ... by cell id ... check box "complete title set" ... hit go ... it ask's for output folder ... you say where ... and wait .
Locate vobcell that contains required data ... open it with vobedit ... demux ... choose mpeg or m2v ... and process .
In vobedit main window is information regarding audio streams type's and id's ... choose correct stream ... hit demux ... choose the required format ... then stream id ... process .
Put these two stream's somewhere safe ... delete all other files associated with this process ... if not required .
Extract video from 2 home DVDs - combine to single DVD with menus
By gutted in forum Newbie / General discussionsReplies: 5Last Post: 24th Apr 2011, 14:31 -
PowerDirector: Extract single scenes from Movie --> HUGE(!) file
By Katzwinkel in forum EditingReplies: 1Last Post: 5th Nov 2010, 16:46 -
Want to keep chapter markers with Vob2MPG in single mpeg
By Pontyac in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Jan 2010, 12:14 -
VOB2MPG Chapter Extract as Text File?
By ron spencer in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2009, 16:01 -
Muxman generates a dvd with only single chapter??!!
By StarX in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2009, 04:24
