Hey forum
I have been racking my brains tryin to fiqure out how I can convert an AVI for dvd that can be viewed on tv only format. Now i wanted to do this by converting IFF files to vob and then goin to a internet cafe and burning that on to a dvd but i am not familair with any program that does that and my premiere pro is outdated. Now the hardware and softwares i have at home for burning are nill-nadda-nothin...I have virtual dub, Media coder, after effects, but i cant seem to render out the files in mpeg2 format. I need as much info and resources that can be provided by everyone...This is for Demo Reel purposes...CG animation,Compositing,Visual effects so the timing and quality have to be excellent and percise..the format-NTSC...Thank you
Just get Ulead DVD Movie factory or Video Studio 10 they are simple to use and offer a 30 trial. You can convert your AVI videos to DVD format with DVD menus if you want.
Thanks maven..I have tried the video studio from ulead..good lsoftware, and i will get right on with the movie factory one...I dont have a burner at home is that goin to cause a problem or can i do this...save the file and then go to an internet cafe and burn it there?
Do you have a CD burner?
If so you can use WinRAR to create a back-up using a file size of 695MB and spread it out over X number of CD-R discs then put it back together again on the computer with the DVD burner.
I would create an ISO IMAGE FILE ... then break that into multiple RAR files (use self executable type and archive with no compression) ... burn to CD-R ... then extract on the computer with the DVD burner.
No fulci, this comps not equiped with iether a cd burner...In regards to the rest of the iso and what not info you gave me..thanks..but im lost...I ve used iso to open up games and programs, ut never the othe way around...now would it be my iff files or avi file that will be converted....and if i choose iether or , without a cd burner, would the files be coverted in sequentionalseperate files, avi- like file or I dont make any sense...
I can convert IFF files to mpeg if you want to send then to me -- other than that you will need 'shake' or 'digital fusion' to convert them ... maybe also in some other program ('combustion' also most likely)
avi to vob to dvd
By anasa in forum Video ConversionReplies: 1Last Post: 2nd Jun 2011, 10:49 -
Hardware needed to convert MKV to AVI and dvd etc quicker?
By spunge85 in forum Video ConversionReplies: 1Last Post: 16th Jan 2010, 07:40 -
DVD (VOB files) to avi
By hilario in forum DVD RippingReplies: 6Last Post: 30th Oct 2009, 11:44 -
trying to convert avi to dvd (vob)
By geronemo in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2007, 15:34 -
What hardware do I need to go from VHS to Mpeg (or avi)?
By RichTJ99 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2007, 01:54
