Hello.
I have a Mini-DV 3CCD camcorder and I want to import about 2 hours worth of video. This will take more space that what I have available on my HD.
Is there a way to convert it on the fly to another format so that it does not take as much place ?
The video will be burnt to a DVD afterwards. What compressed format and of what specification should I use ?
thanks!
Babalou!
The main problem you will run into is that using a more compressed format than DV is you will lose some quality. But you might look into Mainconcept MPEG Encoder. I've used it for DV conversion on the fly to MPEG-2, but it takes a lot of computer power to do that in realtime. The best solution might be a DVD recorder with DV FireWire input.
Alternately, the newest versions of VirtualDub can accept DV, but I don't know if you can convert on the fly to another AVI type format. And you would have the same problem as above; higher compression formats take a fair amount of computer power, especially in realtime, and you will lose quality.
How about an external hard drive? I'm assuming a laptop? If not, consider a second or a larger hard drive.
And welcome to our forums. -
Thanks for your help.
The external drive solution is feasible as I have a friend that can lend me a 20Gb USB2.0 drive. How much space do I need per minute of DV recording ?
And you are right, i'm on a laptop :P
Thanks! -
Figure about 13GB per hour of DV content.
You're going to need a bigger drive
Jim
n00b question on format to use
By hbguru in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 15:08 -
Best COMPRESSED video editing format in Premiere?
By Namie in forum EditingReplies: 8Last Post: 6th Jan 2010, 20:11 -
which is the best software to import/convert VHS to Digital format ?
By james_patageul in forum Capturing and VCRReplies: 3Last Post: 3rd Feb 2009, 19:08 -
n00b: Best format for iMovie '08 and '09
By dagware in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2009, 11:27 -
Which is least compressed format?
By vid83 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 19:59
