Does anyone know a reasonably priced DVD player that will play back live CDs properly - IE no gap between each track - every one I've tried adds one!
Cheers
Isn't this a function of the CD itself? If you don't change the inter-track delay to zero when you record, the default 2 seconds of silence will most likely occur.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
If it is a self-made CD, check the source wavs in a sound editor for in/out silence and cut them out if necessary. Don't forget to set zero gaps in CD creating software. A player itself shouldn't add any gaps.
Cheers, but the CDs play back OK on a CD player and the computer - it's just that both my DVD players stick a gap between the tracks!
Not a major problem - must just be unlucky with my choice of players.
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
Gapless video playback
By punisa in forum Software PlayingReplies: 12Last Post: 4th Oct 2008, 16:02 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:09 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
playback on tv
By andyluong99 in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 17:08
