Other than by the length of the movie, just how can you tell if a store bought or rental DVD movie is doubled layered other than by guessing according to the length?
Thanks.
Results 1 to 27 of 27
Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
Larger than 4.38 GB (in windows) it's likely to be double layered
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
The way I tell and it may not be 100% correct is to look at the color of the bottom side of the disc, If it appears silver in color it most likely is DVD-5, if it is gold colored then it is most likely DVD-9. The length of the movie is a guess. I have seen martial arts movies that were 90min long and 6.5GB in size.
For the most part though, any recent movie is dual-layer...spare very few, so you could just assume it was double layer.
Simply look at the back of the dvd case. It's always written DVD5 or DVD9 or a text like "dual layer disc: layer transition may trigger a slight pause".
Most movies are now DVD-9, i.e. double layered. Some will label them as DVD-9 on the cover.
Sam Ontario -
The movies I am getting are from Netflix so there is no 'box', just a mailing label.
Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things. -
More movies than conventional wisdom will tell you are NOT dual-layered. Of all the movies I buy (or rent) each week, it's almost a 50/50 shot. Some studios just don't see the need for tons of extras that would call for a higher bitrate, in turn ultimately requiring a dual-layer disc. Either that (and/or often in both cases) the movie runs longer than two and a half hours.
Alex_ander's suggestion is the most fool-proof way of determining this without having the packaging. -
True enough of burned dye discs, not so true with commercial pressed discsOriginally Posted by JimmyJoeBob
I like classfour's suggestion - put the disc in the drive and open Windows explorer to look at it.
We get about a 60/40 mix of DVD-9/DVD-5 with Netflix. Of course some of ours are pretty fringe stuff.Originally Posted by handyguy -
Nero Infotool states the disk capacity. If its about 8gb - its double layered. Nobody appears to write a double layer disk of less capacity. Some even duplicate material to pad it out.
Load the disc in DVD Decrypter, it'll specifically say whether it's single or dual layer (I find it easier to see this in ISO mode).
Scott -
Hold the disc on its side and count the layers.
Sorry guys I just couldn't resist.
But truely. Aren't there a few companies that have used dual layer media for all off their releases? So when they need it it was available.
I could be very wrong on this. but I thought I remember reading it somewhere. -
I have been, but I was told "if I don't stop it, I'll go blind"...............Hold the disc on its side and count the layers.
Or was that something else?Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things. -
I sure wish i could find these gold & silver recordable dvdr'sOriginally Posted by Capmaster
:P
(oh yeah, welcome back lurker.. i noticed the other day surfing through after i was wondering who was digging up all those old thread's
Not here (U.S.)... i have a lot of store bought pressed disc's that state neither.Originally Posted by cd090580
Lot's of good way's to tell as stated here, i use DVDInfoPro & DVD Decrypter if i really need to know before ripping, if it really mattersOriginally Posted by videobruce
Or as stated windows explorer, nero inof tools, ect ect ect....... -
Why is everyone giving advice on how to copy a rental? OP stated the dvd's are from Netflix.
I meant looking at commercial DVDs and being able to tell the density by its color. DVD-5 dye burned are purple and many times DVD-9 are gold. But the commercial DVD-9 are always silver.Originally Posted by Noahtuck
Thanks. It's good to be back. I see someone claimed my top "All time poster" spot. Gotta work on that
Those old threads aren't "old threads" to me. I've been on hiatus here since April 2005, so everything is a new thread
Seems to me, he just wanted to know what the size/structure was. Since when did that become a crime, even for rentals?Originally Posted by Dr_Layne
Scott -
Originally Posted by Dr_LayneHmmm... i must have missed the part where he asked how to copy themOriginally Posted by MOVIEGEEK
Strikes again
The MPAA has enought $$..............Since when did that become a crime, even for rentals?Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
Turn it over and look at the hub!!! You can see the layers Id'd there!!! Some even say LO and L1
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
OP:
Sorry I jumped the gun on thinking you were copying rentals,nobody on here does that.
I use DVDDecrypter to see what the properties are. -
Use info software to find out. There is plenty of free stuff. I use Plextor Tools, which comes with their drives.
megui convert video how to keep orginal aac audio
By jamespoo in forum DVB / IPTVReplies: 0Last Post: 24th Jun 2011, 23:11 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
DVD to mkv with same quality as orginal?
By abel1 in forum DVD RippingReplies: 15Last Post: 3rd Jan 2010, 15:05 -
How can I turn on a audio by Ifedit? Add button to orginal menu
By schtroumpfs in forum Authoring (DVD)Replies: 4Last Post: 11th May 2009, 10:20 -
Converting layered WMV files to MOV
By whoisquilty in forum MacReplies: 3Last Post: 19th May 2007, 14:18
