Is it possible to make a non-standard SVCD mpeg2 file with Cinema Craft Encoder, using 640x480 resolution and standard bitrate? The Tmpgenc encoded files I burn with Nero 5.5 play fine but take so long to make using the higher resolution.
The last civilization will not be another civilization. It will be that long stretch of realization to which all other civilizations have pointed.- A. Miller
Tried it and it works, but the CCE SP2.5 encoder still takes over 2 times the length of the clip to make an XSVCD with 640x480 resolution and 2500bps.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
