In most of my applications and on the internet when I try to "open" a video or "save" a video the dialogue box takes a minute or so to open. At first I thought the applications were hanging but if I wait long enough the dialogue box does open.
For instance when using VideoReDo I hit the big OPEN button or use file/open and nothing happens for over a minute. Then the dialogue box opens and all works fine. If I drag and drop a video to VideoReDo it opens instantly.
On the internet when downloading a video If I right click and choose "save target as" it takes a minute or so for the dialogue box to appear.
I'm not sure when this started. I use several computers and I just now realized that this is a consistant, repeatable problem on this computer only.
Ideas?
Added Later:
Just found out that if I log in as a different user the problem vanishes. That means I can probably just use that new log in and delete the bad one. Still I would rather just fix the problem. Any ideas?
Results 1 to 10 of 10
Do you have any network drives mapped to drive letters?
When Windows creates an open/save dialog, it has to populate it with a list of all the drives on the computer. This includes any shared network drives mapped to drive letters. There is a timeout period - Windows will wait that long before deciding the drive isn't available. About 5 to 10 seconds is typical.
So, if at work (say), you have a network drive mapped to Q: and you are on the network, things will be quite responsive. Now, if you are at home or travelling, Windows still thinks you have the Q: drive, so it will try to connect to it. Since it isn't there, you will experience a delay equal to the timeout period.
The more network drives you have mapped to letters, the longer the whole delay.
The solution (that I use) is to simply create a shortcut on the desktop to the network drive (using the full UNC, not a drive letter) and not map any drives to drive letters.John Miller -
From the looks of the computer you describe in your profile, I suggest that you donate it to the Smithstonian and get some money from that dog and buy a modern new computer that runs on electricity.
Originally Posted by SCDVD
Nothing wrong with presto's computer. I still use a 600MHz box for some stuff.
No wonder there's so much electronic junk in our landfills.John Miller -
Thanks Johnny M
I only had one mapped drive and I just disconnected that so that is not the problem. I have three computers on my desk (I use a KVM switch). The computer I have this problem with has 2.07 GHz.
The one in my profile works fine for my non-video stuff so I won't be getting rid of it soon. -
Did you disconnect it or did your unmap it?
Even when disconnected, Windows tries to find it (that's been my experience).
Go to the command prompt and try:
Code:net use
John Miller -
cmd/ net use reports "nothing in list".
I created a new user and I'm migrating over to that. All seems to work fine now. -
if the last time that open or save box appearing was used to access a drive on a network, windows will slow to a crawl, because it is trying to display the last path that was used, which was a network drive.
does that even make sense?I am just a worthless liar,
I am just an imbecil -
Thanks All
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 15:26 -
Adobe Acrobat Reader Save and Open Location?
By bevills1 in forum ComputerReplies: 5Last Post: 24th May 2011, 16:55 -
Question about disappearing program in the "Open with" dialogue
By jimdagys in forum ComputerReplies: 2Last Post: 4th Dec 2009, 03:35 -
Save Box Mailbox Function
By guns1inger in forum FeedbackReplies: 15Last Post: 1st Dec 2008, 23:42 -
help~ cant open my mov
By Kimgris in forum Video ConversionReplies: 2Last Post: 12th Jul 2008, 13:20
