Can Mpg4 work with every dvd player - prehistoristic and new?
I read that it can give you 10 hours of video on dvd and 2 hours of video on cd. I think that's great.
If it can, is there any authoring programs that are similar to DVD Lab pro that can manipulate mp4? The reason i asked is, when i compile a project with dvd lab pro, it puts the output in a folder and then i burn the folder with nero and it works. However, whenever i try to tell it to burn the dvd itself, it doesn't work. It's very similar with Sony Dvd architect. If i have to switch apps in order to use the mpg4 format then i would. It's just that the app has to be capable of doing that.
How's My English?
No. And for 99.9% of the players which support mpg4 (in the shape of DivX/XviD AVI) they can't be autored at all, just written as data to the disk.Originally Posted by wan2no
A few DivX Ultra certified players allow you to author (of sorts) using the DivX container, with DivX Media builder.
/Mats
Vob 2 MPG - PS3 compatible specific problem
By Herdsmann in forum Newbie / General discussionsReplies: 17Last Post: 18th Jul 2010, 23:44 -
So what do I do with "NTSC Compatible" .mpg file?
By brassplyer in forum Authoring (DVD)Replies: 6Last Post: 29th Sep 2009, 15:12 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
