    Nov 2004
    In your mind
    I used to turn on this computer and I was at the desktop.Then I had to use restore discs to fix some stuff,get some original programs back and now when the computer is turned on it goes to the logon page first (where you click on your name and picture).How can I get back to turning on the computer and going right to the desktop,skipping that logon page? Thank you.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    From memory:
    Go to Control Panel > User Accounts, and untick "Use Welcome Screen".
    If that ain't it, try:
    http://www.google.com.au/search?hl=en&q=windows+xp+logon+automatically&meta =
    If in doubt, Google it.
    Nov 2004
    In your mind
    $%@&*%!@$^ Ha-Ha-gotcha and you don't even know it. Thanks for the help mate.
    Jul 2001
    Hmmmm. A pc with an account with no password. Sounds like an opportunity...
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
