I just fixed my probelm of not being able to load .avi's into Movie Maker (I had to download a codec pack)
Now I'm having trouble opening certain .avi's in Animation Shop. I'm able to open an .avi movie which is 700MB with no problems but I can't open my TV shows which are 350MB.
When I try I get this popup:
How do I fix this?
By installing the codec the AVI uses. Use GSpot to tell. Then install the missing codec (and only that codec). Installing that codec pack may well have butchered your video playback capabilities beyond repair.
/Mats -
This happened before I downloaded the codec pack also. I'll try that though, thanks!
OK - What codec? Sure you got the latest version? Tried rendering it (in GSpot)?
/Mats
What do you shop online for?
By johns0 in forum PollsReplies: 15Last Post: 19th May 2010, 17:19 -
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 19:43 -
What Is Up With SVP Blank Disc Shop?
By hech54 in forum MediaReplies: 2Last Post: 9th Jul 2009, 01:22 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 09:01 -
PROBLEM: Animation Shop Won't Export To Paint Shop Pro 8
By Aaron1927 in forum EditingReplies: 1Last Post: 10th Jul 2007, 10:44
