I'm trying to make a simple menu using DVDAuthorGUI 1.008b, and I keep getting the following error
I know I'm probably missing something obvious,DVDAuthorGUI 1.008b - 1/14/2006
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
A subdirectory or file C:\DVD volume\1\1 already exists.
***please wait while the titles are multiplexed.
*generating button images.......
*generating highlight button 1 for menu 1
*generating select button 1 for menu 1
*multiplexing menu 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File C:\Documents and Settings\l\My Documents\dvd author projects\bunyipalt 1.m2v looks like an MPEG Video stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 0 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\l\My Documents\dvd author projects\bunyipalt 1.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 7500000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 7655000
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Scanned to end AU 0
INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] STREAM e0 completed @ frame 0.
INFO: [???] Multiplex completion at SCR=4096.
INFO: [???] Video e0: buf= 183761 frame=000000 sector=00000027
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 53807 bytes
INFO: [???] Sequence headers: 1
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 0
INFO: [???] No. Groups : 1
INFO: [???] No. I Frames : 1 avg. size 53807 bytes
INFO: [???] No. P Frames : 0 avg. size 0 bytes
INFO: [???] No. B Frames : 0 avg. size 0 bytes
INFO: [???] Average bit-rate : 10761200 bits/sec
INFO: [???] Peak bit-rate : 0 bits/sec
INFO: [???] BUFFERING stream too short for useful statistics
INFO: [???] MUX STATUS: no under-runs detected.
DVDAuthor:pumux, version 0.6.12-alpha-2907.
Build options: gnugetopt iconv freetype
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
STAT: 0:00:00.000
INFO: PNG had 2 colors
INFO: Constructing blank img
INFO: Pickbuttongroups, success with 1 groups, useimg=1
INFO: Found EOF in .sub file.
INFO: Max_sub_size=214
WARN: Read 0, expected 4
INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
Statistics:
- Processed 0 subtitles.
- The longest display line had -1 characters.
- The maximum number of displayed lines was 0.
- The normal display height of the font arial.ttf was 0.
- The bottom display height of the font arial.ttf was 0.
- The biggest subtitle box had 214 bytes.
erase "C:\DVD volume\1\1\menu1.mpg"
echo *authoring title(s).....
"C:\Program Files\DVDAuthorGUI\bin\dvdauthor.exe" -x "C:\Program Files\DVDAuthorGUI\config.xml"
DVDAuthor::dvdauthor, version 0.6.12-alpha-2907.
INFO: Locale=C
C%3A%5CProgram%20Files%5CDVDAuthorGUI%5Cconfig.xml :113: parser error : Input is not proper UTF-8, indicate encoding !
Bytes: 0xF1 0x61 0x72 0x5C
cuments and Settings\l\My Documents\My Received Files\LG15\Tito Puente Dejame so
ERR: Error in parsing XML
erase "C:\DVD volume\1\1\*.mpg"
echo *process complete
*process complete
Error code #4
There was an error in the name or path of the files. Please use standard english characters for the folders/directories.
OK, worked it out myself. Some of the file names had foreign accents over the top of them.
Thanks anyway, you guys rock, this site is a great resource.
XML Error in windows media player
By Dj-Viper in forum Software PlayingReplies: 0Last Post: 10th Dec 2009, 15:41 -
parsing an avi file
By pi-1966 in forum ProgrammingReplies: 0Last Post: 27th Apr 2009, 05:08 -
Megui xml error
By headhunter03 in forum Off topicReplies: 0Last Post: 4th Apr 2009, 09:19 -
DVD authoring fails - 'error in parsing XML'.
By Levina in forum ffmpegX general discussionReplies: 12Last Post: 22nd Mar 2008, 09:10 -
Parsing error
By screenhoofd in forum ffmpegX general discussionReplies: 6Last Post: 6th Oct 2007, 07:17
