Hi all,
I bought a TV tuner from e-Bay loaded with Philips 713X Chipset. I expereince problem with sound (loud hiss allover the band) I realize many people with the same Chipset have similar problem.
If anybody has a clue about solving the problem please inform me!
Thank you all
Thread: Philips 713X Chipset
There is an issue with the SAA7134. This device only works properly with samplerate set to 32 KHz.
However, the driver offers 48 kHz, which sounds distorted. It might even offer 44.1 KHz (dependent on the driver version/config) shich is unusable (as far as I remember).
In any case you should check for a driver update!!Best regards
Friedo
TerraTec Electronic GmbH
Picking a Capture Card chipset, going in circles..
By LukeS in forum Capturing and VCRReplies: 22Last Post: 21st Oct 2011, 07:21 -
Does a Motherboard's Chipset Make a Difference?
By wulf109 in forum ComputerReplies: 1Last Post: 20th Oct 2011, 10:43 -
HP/Compaq D530 SFF Motheboard - Chipset ???
By blinky88 in forum ComputerReplies: 3Last Post: 6th Aug 2009, 14:42 -
Philips SAA7134HL chipset Tv Tuner card !
By ganduman in forum Capturing and VCRReplies: 6Last Post: 5th Jan 2009, 02:43 -
Best tv tuner chipset just for getting channels best
By blitter2 in forum Capturing and VCRReplies: 0Last Post: 26th Dec 2008, 08:01
