I recently purchased the Philips DVP5960 DVD player with the intention of connecting my SMARTDISK FIRELITE 80GB harddrive to it via the USB port to watch movies on it. This was anything but successful...After determining it would only read FAT32, I ended up buying a $70 piece of software to reformat my FIRELITE from NTFS to FAT32 (windows won't format drives to FAT32 if they are over 32 GB)...No luck...Still wouldn't read it...Then I read somewhere that it would only read hard drives that had external power sources (FIRELITE is powered solely through the USB connection), so I bought a MAXTOR drive from a friend...Another $60 down the drain cause it wouldn't work either. I called Philips and even they couldn't give me a list of hard drives that it would read...So back to the store it is going!
Now I am back to square one (well, minus like $140)...Does anyone know of a DVD player that DOES work? One that will play any (or at least most) external hard drives? Maybe even one that came with a list of compatible devices? I am at my wits end! Any help or direction in the matter would SOOOOO greatly be appreciated! Thanks!
Oh crap...Nevermind...I should read posts here more carefully...Someone solved my problem...My harddrive wasn't set as Primariy...I tried that and it FINALLY worked!
Disregard...and THANKS!!!!
Connecting USB harddrive to Philips DVP-5990/37 player
By DVantrease in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Aug 2009, 20:30 -
Best DVD Player that plays Movies from External USB Drives
By jdennis in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Apr 2008, 13:43 -
If I purchase a low end DVD player just to watch movies....
By leftyloopy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Feb 2008, 15:02 -
DVD player with way to update DivX codec or usb to watch vids from? Exists?
By spycam in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Oct 2007, 22:05 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
