I cant get any picture when capturing from my jvc digital video cam, I am connected via "firewire cable" I can start the cam using the comp's remote but get the message
"unable to switch to capture mode" failed to build a preview graph.
maca
What software are you using? I haven't had any issues on my WinXP box using WinDV to transfer the video from the camcorder to the PC. On my old Win98 box I had to use DV type 1 to avoid the audio sync issues I had when using DV type 2.
This might also be a hardware problem - have you tried hooking the camera up to a different firewire port, or hooking it up to another computer altogether?
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W. -
Is there an error log for your software? Sounds a software/driver issue since you can control the camera but it is "unable to switch to capture mode".
Google is your Friend -
Turn off the camera, then unplug the firewire from the pc. Shutdown any capture/video software. Not pluc the firewire back into the pc and turn on the camera. The computer should bring up a menu of softwares to select for the capturing. Select your software, and see if it connects. Your capture software might also be trying to use WMV drivers instead of your dv-avi drivers. You can check the options/preferences in your capture software to see.
Rob
DVD "Unreadable" - Can I backup data on my comp?
By TechFool83 in forum ComputerReplies: 24Last Post: 24th Dec 2011, 11:22 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Newbie Frustrations - VHS to DVD or Comp Help
By BrianJ844 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Aug 2010, 11:01 -
Making a comp. DVD with DVD-Lab Pro..
By Superstar24 in forum Authoring (DVD)Replies: 1Last Post: 26th Jul 2009, 18:24 -
Creating a Comp DvD problems
By JKG in forum Authoring (DVD)Replies: 1Last Post: 27th May 2007, 04:15
