    Nov 2006
    Australia
    Hi, i was wondering if anybody could tell me how i can add avi files to itunes. Do i need to convert them and if so what program do u recommend?? Thanks for your help!!
  2. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    I haven't converted AVI files, but this works well for MPEG files. It's twice as fast as Videora iPod Converter. It's more user friendly, too.
    http://www.adstech.com/products/RDX-160/specifications/RDX-160_spec.asp?pid=RDX-160
    Compatible Formats:
    Most standard video files that you can play on your PC
    MPEG-1
    MPEG-2
    VOB (unprotected)
    DivX
    Quicktime Movie
    Some people might suggest a program called SUPER. Be sure to check this post, though.
    https://forum.videohelp.com/viewtopic.php?p=1593917#1593917
    Nero Recode! Or google for "avi to ipod" for 1 million hits.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Though, that's really only an issue if you're using more than one Cygwin-related program. (Actually, I've used more than one on a system with SUPER installed, and haven't had any noticable problems. Your mileage may vary.)
  5. Member Epicurus8a's Avatar
    Compatible Formats:
    MPEG-1
    MPEG-2
    VOB (unprotected)
    DivX
    Quicktime Movie
    BTW, I just tried the InstantVideo To-Go with an avi file without any problems. Once again, Instant Video To-Go is twice as fast as Videora iPod Converter, and about three times as fast as SUPER. IMO, the quality is better too.
