It isn't but it is. You see when i play the avi file it is fine, but when i try to convert it using TMPGEnc, the program thinks it's about 5 hours long, when it's actually about 2 hours long, but it then makes the file size about double. Does anybody know how to make the program think it's not 5 hours long? Maybe video properties, or settings inside TMPGEnc?
www.videohelp.com/tmpgenc#problems , first problem.
or use something else for downloaded video like divxtodvd.
VFR - Video Length Issue
By olcifaraga in forum EditingReplies: 0Last Post: 26th Apr 2012, 03:01 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
flv with no video length
By tv3636 in forum Newbie / General discussionsReplies: 6Last Post: 30th May 2009, 16:47 -
Calculating Video Length
By scan in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2008, 13:33 -
Video 2X the length of audio after demux
By pchan in forum EditingReplies: 6Last Post: 18th Sep 2007, 23:51
