I captured an old VCR tape to .AVI format. The volume of it is decent. I then encoded it to Mpeg II useing the software called Super. But the problem is, when I use Super to encode the AVI file, the volume is softer/lower than the volume of the originial .AVI file. I went into options of Super and raised the encoder volume to max(300) but it had no difference on volume the encoded Mpeg II file. I also went into the Windows volume control panel and maxed out the Line In and Stereo mixer volume levels, but it didn't make difference. Any suggestions?
Video Audio Volume level
By Directlinq in forum Video ConversionReplies: 2Last Post: 16th Nov 2009, 13:43 -
[Solved] How to normalize various wav files to same volume level?
By freebird73717 in forum AudioReplies: 3Last Post: 30th Sep 2009, 17:22 -
How do you know the volume level of each channels in a 5.1 track?
By zee944 in forum AudioReplies: 2Last Post: 7th Sep 2009, 10:54 -
can increase audio level using SUPER?
By buzzinhornets in forum Video ConversionReplies: 8Last Post: 13th Sep 2008, 06:38 -
how to adjust average volume level to a given dB value? (.wav file)
By zee944 in forum AudioReplies: 5Last Post: 10th Jul 2007, 10:06
