Results 1 to 20 of 20
    Jun 2006
    Singapore
    Tool used : avisynth, virtualdub
    I have problems, playing .rmbv file that encode into .sivx using divx 6 compression and ac3 format.
    when i try to playback, an error with this comeout...
    D:\My Documents\OMFC 2006.avi::Output
    Media Type 0:
    Unknown
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770}
    subtype: MEDIASUBTYPE_Avi {E436EB88-524F-11CE-9F53-0020AF0BA770}
    formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 0
    Media Type 1:
    Unknown
    AM_MEDIA_TYPE:
    subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
    lSampleSize: 1
    cbFormat: 0
    Can you play other divx with ac3? you might need the ac3 filter?
    Does it work with mpc or vlc?
    Jun 2006
    Singapore
    ac3 is installed since ive downloaded klite mega codec pack.
    problem is i want it to play on my divx player
    Jun 2006
    Singapore
    help
    Nov 2002
    What if you choose MP2 audio instead?
    Jun 2006
    Singapore
    actually the problem is what? the conversion or the audio codec choose?
    Jun 2006
    Singapore
    so nobody going to help me? wtf?
    Feb 2004
    If you don't answer people's feedback (eg, 1st reply from Baldrick - Does it work with mpc or vlc?)
    then you can't expect them to keep typing stuff in ?
    If it plays ok in mpc or vlc then this might suggest that the files are valid.
    If not, then the files are invalid and they'll probably never work on your standalone player.
    Good luck.
    Jun 2006
    Singapore
    no, it doesnt work on MPC and VLC
    Feb 2004
    does it play the video without sound ?
    or vice versa etc....
    the more details you supply the better....
    You may find it more successful if you "demux" the audio from the video (in virtualdubmod) and convert each separately and then "mux" them back together (in virtualdubmod) ?
    Alternatively, have a look at this post :
    https://forum.videohelp.com/viewtopic.php?t=281724
    or this one :
    https://forum.videohelp.com/viewtopic.php?t=212204
    again, good luck !
    Jun 2006
    Singapore
    Hi steve,
    Nope, it doesnt play the video at all. A popout window containing the error came out right after i open the file.
    im using virtualdub, not virtualdubmod, and i dont know whats the difference.
    This problem also occur when i tried to convert Xvid into Divx 6
    and of course as stated, rmvb as well.
    please help me.
    im begging.
    thanks alot
    Feb 2004
    If you follow this guide - https://forum.videohelp.com/viewtopic.php?t=284288
    (install Real Alternative and avisynth)
    Can you open the file in virtualdub successfully ? without errors ?
    If so, in virtualdub, demux the audio - File menu, Save WAV...
    Convert the WAV file to AC3
    https://www.videohelp.com/tools?toolsearch=&s=&convert=WAV+to+AC3&orderby=Name&Submit=S...+or+List+tools
    Then back in vdub, select No audio (in the Audio menu). In the Video menu, select Full processing mode, then click Compression (also in the video menu) to select the DivX codec.
    Configure your bitrates etc... OK everything and then File menu, Save as AVI...
    (if you want to do a 2-pass encode, then there's a bit more to do, let me know if you need help)
    Then open the video file and add the audio file you converted, (select direct stream copy in video menu - no compression this time) save as AVI again.
    Job done !
    I don't know if virtualdub lets you add AC3 files but virtualdubmod does allow this.
    Good Luck...
    [/img]
    Jun 2006
    Singapore
    hi it works, now. thanks alot. really thanks alot.
    however, is there anyway i can boost the audio to make it more loud? coz it is so soft... i nd toopen my tv volume very high...
    is there any software that can boost the .ac3 format volume
    and also, where can i read more about virtualdubmod? coz i previously using virtualdub and it can only import wav format
    thanks in advance
    Jun 2006
    Singapore
    can anyone help me?
    Nov 2002
    BeSweetGUI or BeLight can do some postprocessing to AC3s
    Jun 2006
    Singapore
    that software sucks. i cant even convert using it. im using ffmpg
    Nov 2002
    Which one? They are actually the same, just different GUI. I haven't had any problem with them. Perhaps you need to describe the problem?
  18. Member
    Feb 2004
    Use BeSweetGUI or BeLight to increase the volume (extract BeSweet to the same directory as BeSweetGUI/BeLight)
    IMO Besweet GUI is a bit harder to use than BeLight.
    In BeLight, the options you need are available in the "Advanced Settings".
    Quoted from "Stealth3si"
    NOTE. all other settings should be the same so that your entire audio format remains the same (Kbps etc...)
    You have 3 options to raise the volume
    1. change the boost levels (3-7, 0.95)
    2. change the normalization levels (100%)
    3. use HYBRID Gain levels to adjust automatically for you
    - you can also combine the 100% normalization AND boost levels to make it even louder
    Good Luck.
    Jun 2006
    Singapore
    can tell me the steps to change
  20. Banned
    Jul 2005
    US
    SPAM
