My problem is that when I load up my movie in mpeg2 form, and then the audio in ac3, into ulead dvdws 2 the audio is ahead by about 7 secs, right from the start. I converted my movie from avi with virtualdub from 23fps to 25 and coverted to mpeg2 with TMPGenc. I extracted the audio and converted to the same frame rate with besweet. The time codes for both video and audio are the same ( I just play both in media player to check the times). But when I load them into dvdws theyre off. I have used the same method to convert several movies before with no problems, only recently has it been affecting all the movies I try to convert to dvd. Please help, this is driving me mad. cheers
A bit of a work around (aka Bodge!) but if the audio is a consistant 7 seconds ahead of the video right through the whole video, why not just add 7 seconds of silence in front of the audio?
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 05:10 -
DVDWS 2 and Premiere Pro2 and jerky dvd
By paul ward in forum Authoring (DVD)Replies: 5Last Post: 16th Apr 2009, 08:49 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
