    Dec 2006
    I have a problem with my tv in card and dvd player clashing.
    my dvd player is a yamada dvr-800 and yv in card is an old one made by the pine group and uses the B878 chip.
    I am using a composite lead for video.
    I get a black vertical bar moving from right to left (as I loook) once the bar reaches the left side the picture flashes bright then the bar appears again at the right side and off it go's again.
    I am new to all of this so please forgive me if more info is needed.
    Thanks..
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Verify you DVD output is interlaced and not progressive.
    Google is your Friend
    Dec 2006
    Thanks I will try that. (checked its set to interlaced)
    I have been told it could be macrovision also
