    Dec 2006
    hi all, ive used the film machine for a cpl of years trouble free encoding.
    but i have recently experienced a problem.
    The Film machine starts transcoding the audio, and complete's then quenc starts to encode video, after about 10 mins the program just shuts down.
    ive re installed numerous times, ive even made sure after a uninstall that the registry files are removed with reg edit.
    so after lots of headbanging i downloaded avi2dvd, and tried that, and whould you believe it it does the same.
    oh and i have tried converting 3 different avi's, all with the same result.
    any ideas guys, the problem must be with my pc but what
    as my dear departed grandpa used to say time is not important until your 80
    try the old free DivXtoDVD.
    Dec 2006
    hi this is the log file generated after avi2dvd stopped any idea's.
    will give the other application a try tonight
    [20:48:23] AVI2DVD Started
    [20:48:25] Type mode : Avi Input
    [20:48:25] Output : Dvd
    [20:48:25] Encoder Selected : QuEnc
    [20:48:25] Start demuxing the AudioStream No.1 ...
    [20:49:00] Demuxing of the selected audio finished successfully ! [C:\Program
    Files\eMule\Incoming\Avi2dvd_temp\Extracted_Audio. mp3
    97526544 Bytes]
    [20:49:00] Starts Audio correction ...
    [20:49:10] Audio Fixed successfully ! [C:\Program
    Files\Incoming\Avi2dvd_temp\Fixed_Audio01.mp3
    97526544 Bytes]
    [20:49:10] Starts Mp3->Ac3 convertion ...
    [20:49:22] Audio converted in Ac3 successfully !
    [C:\Program
    Files\Incoming\Avi2dvd_temp\AudioStream 1 MP3
    2CH.ac3 8306688 Bytes]
    [20:49:22] Start creating avisynth script ...
    [20:49:22] Avisynth script created successfully !
    [C:\Program
    Files\Incoming\Avi2dvd_temp\Avisynth_Script_File.
    avs 172 Bytes]
    [20:49:23] Bitrate used : 5653 Kbpps
    [20:49:23] Start video encoding ...
    [20:53:43] Video encoded successfully ! [C:\Program Files\Incoming\Avi2dvd_temp\Encoded_Video.m2v
    0 Bytes]
    [20:53:43] Job NOT Done. There are warnings ... Find at the log file the 0 byte generated file to focus where exactly the problem appears
    Dec 2006
    Please please help any ideas !!!!!!!!!!
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If this file still exists
    C:\Program Files\Incoming\Avi2dvd_temp\Avisynth_Script_File.a vs
    Try opening it in virtualdub to see if a) it opens and plays, and b) what error message it produces if it does not.
    Read my blog here.
    Dec 2006
    thanks for the idea
    the file exists but it is listed as only being 1kb in size, i dont think there is anything to open
    anymore ideas heeeeeelp
    Apr 2004
    Miskatonic U
    It is a text file that contains the avisynth script that is the filmmachine uses. Open it in virtualdub and either your video will open, or you will get an error message. Either way it will help narrow down the search for an answer.
    Read my blog here.
    Dec 2006
    [i] VirtualDub CLI Video Processor Version 1.7.0 (build 25854/release) for
    80x86
    [i] Copyright (C) Avery Lee 1998-2006. Licensed under GNU General Public
    License
    [*] AVI: Opening file "C:\Program
    Files\Incoming\Avi2dvd_temp\Avisynth_Script_File.a vs"
    [i] AVI: Avisynth detected. Extended error handling enabled.
    [*] Beginning dub operation.
    [i] Dub: Input (decompression) format is: YUV420.
    [i] Dub: Output (compression) format is: RGB888.
    [*] Ending operation.
    the program ran the AVI quickly about 2 x normal playback, and the above was the output log.
