l have a wmv file, but the windows ME think it is a avi. file, how can l make the windows ME recongnizes it as a wmv file?
I'm not that familiar with ME, but try looking at any folder and see it there is a 'Tools' listing. If so, look for 'Folder Options'. That should give you a 'File Types' tab. Look there for the .wmv extension. Set it to open with 'Windows Media Player. There should be other settings there also that may determine what program can be associated with an extension like .wmv. I suspect you installed a software player that took over the extension at some point.
FOURCC Change
By anirban in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 20:35 -
So you've got to much change...
By Faustus in forum Off topicReplies: 28Last Post: 13th May 2008, 10:00 -
How do I use subtitles with .txt suffix?
By akulier in forum ffmpegX general discussionReplies: 3Last Post: 19th Feb 2008, 18:13 -
how do i change from +R to -R
By offensekilla in forum Authoring (DVD)Replies: 1Last Post: 29th Aug 2007, 07:55 -
Final Cut sometimes creates a 2nd file with a "-v" suffix when ca
By jeromedroz in forum MacReplies: 0Last Post: 2nd Jul 2007, 08:41
