Well my JWL cfs kit is finally failing. So I think I just want to get some refillable carts without the whole tube attachments. So what cartirdges should I be looking to get and from where?
What We Do In Life, Echoes In Eternity....
Once my JWL fails I will be getting these refillable cartridges:
http://www.printforless.tk/
Good Luck -
Do these all use hoses? or are they just refillable carts?
What We Do In Life, Echoes In Eternity.... -
Oops I originally clicked on the r200, 300 CIS. I just found the Refillable Smart Cartridges. Is that what you were trying to refer me to before?
Also, I have about 90ml of each color (dye) from my JWL kit (just bought refill kit, and the cfs started giving me problems) so If I were to use whats left from my JWL, and then when empty, is there anyway to clean these carts so I can then use ink that is not from JWL? Or should I still just get the ink from JWL since it's only $50 for 600ml?What We Do In Life, Echoes In Eternity.... -
Yes the Refillable Smart Cartridges. I still have a full set of ink from JWL. So when I order the Cart's I will be using the ink from JWL. I will order the Cart's in Feb or March...
one question-why not buy another kit?
Did you end up not liking it?PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
The CIS I have enjoyed, but the refill process can be a pain. Plus sometimes I have had issues with the tubes. I just feel the cart's are an easier way. Yes you will fill them up more but, you don't need to worry about the tubes getting air in them or getting kinked in the printer...
Another Great Thread is here on the CIS we have:
https://forum.videohelp.com/viewtopic.php?t=241206 -
I've had my JWL cfs for 2yrs and have loved it, but recently it's been giving me problems. Last week, I refilled all my tanks, and 2 days later my magenta was totally gone, hose was even full of air? Ink didn't leak out of printer, must have been absorbed by the pad, but I did lose over 60ml of my magenta. If I had, had refillable carts, I wouldn't have lost that much, it just sucked it right out of the resevior. Plus it's been clogging alot so I have had to do several cleanings (used the ink bottle mod) wasting way to much ink....
So will these carts let me know when I'd need to refill them, and how much to put in?What We Do In Life, Echoes In Eternity....
Halp! Missing time when dumping video
By 0liver in forum LinuxReplies: 5Last Post: 14th May 2009, 17:28 -
Dumping Comcast, looking for ATSC tuner card.
By gadgetguy in forum DVB / IPTVReplies: 25Last Post: 27th Jul 2008, 17:10 -
Dumping RCA A/V output to Linux
By sdhoigt in forum LinuxReplies: 7Last Post: 4th Dec 2007, 12:40 -
Retailer is dumping current version of Zune
By SingSing in forum Newbie / General discussionsReplies: 3Last Post: 16th Oct 2007, 23:44 -
When are retailers going to start dumping DVD-recorders without HD tuners?
By David K in forum DVD & Blu-ray RecordersReplies: 4Last Post: 23rd Jul 2007, 11:28
