Hey guys,
i need to back up some UK dvds to take with me to the US but the regions are different. Does anyone know of any software that will convert my discs so that they will play in an american dvd player?
Lisawatsuk
Results 1 to 12 of 12
Another option is to get a cheap DVD player that you can region hack.
I did that because my mum collected a bunch of free BBC comedy DVDs from the Daily Mail for me. I got a $29 DVD player, found the region hack and that was that!John Miller -
It can easily be done by three pieces of freeware and three folders for each rendering step. This assumes that these software can go over the copy protection. DVD Decrypter to rip the files to the hard drive into folder 1. Then use VobBlanker to change the attributes of the VOB files from PAL to NTSC. Render into Folder 2. Then use DVD Shrink to re-render the files in Folder 2 to burn a DVD. The process takes about 30-40 minutes, about 10-15 minutes each step. It doesn't get any easier.
The only problem I had is that the menu might have to be accessed from the remote control. Other than that, it's like the original PAL DVD. -
Does RayH option really work?,,does it have similiar problems to other DVD trcikery for pal<>NTSC as in some dvd players will work with it others not?
Anyway, get a usa dvd player that can be hacked and will play pal on an ntsc tv, philips comes to mind.Worth the money my friend.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I have a Cyberhome 300S and a Philips DVP 642. It's my overseas PAL DVDs that I'm converting for someone who has an old DVD player that doesn't even support VCDs!
But like anything else, there's no guarantee that such will work in all players. But if you have to convert, this will do it about as quickly and simply as anything else.
I tried to use Nero Vision 4 and I couldn't get the subtitles and menus at all. Also, it took over 3 hours. The above method just had to access the menus with the DVD remote control. The total time is about 30-45 minues, depending. -
Sorry to sound Know all ish, get your friend a new dvd player, anywhere from 30-50 us$ and just use dvd dhrink et al and give him the dvd's,much much quicker
I tried. My friend doesn't want a new DVD player. I tried to explain it would make my job easier. It's not just about DVDs. I have movies in all sorts of formats: VCDs, DivX, Xvid, etc. I wanted to get her a Philips DVP 642 for $40. She wouldn't accept it. I use AnyDVD and Nero Recode to copy DVDs. Much faster.
I've been buying NTSC DVDs in the States and playing them on my European Sony DVD player and TV with no problem. Is there meant to be a problem? Sorry for the hijack (and the TV cost 150 euros so it is not fancy!)
No there isn't. A vast majority of all PAL equipment handles NTSC too. Problems arise when trying to play PAL on NTSC equipment.
/Mats -
A lot of the US sold DVD players won't support PAL disks. I guess the theory being that Region 1 disks should be NTSC!
Originally Posted by RayH
It's not because the disks are PAL that they won't play, it's because there aren't Region 1.
I would expect almost every DVD player out there will play NTSC and PAL, as long as the Region Code is right.
Personally, I'd insist that your friend accept the offer a free, cheapo player. I certainly wouldn't waste hours and hours converting disks. I mean, a hackable DVD player for less than $30. Good grief, Charlie Brown.John Miller
Looking for a converter
By zf1223 in forum AudioReplies: 5Last Post: 28th Jan 2011, 20:03 -
converter
By buzzyy in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2010, 23:32 -
HD Converter
By Stevo1975 in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2010, 17:48 -
RM Converter
By imero in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2007, 19:44 -
Need a converter that can do this...
By rindless in forum Video ConversionReplies: 2Last Post: 7th May 2007, 04:15
