Hi hopefully someone can help me out on this. I have a DVD and on the packaging it says
"This is a PAL/Region 2 DVD WHICH WILL NOT PLAY ON STANDARD US DVD PLAYER-you need a multi-region PAL/NTSC compatible DVD player to view it."
I live in Canada so obviously I don't have a PAL machine. IS there a way for me to Reencode or rip this DVD on my PC? If so how?
~Kyle.
Have you tried play it? your dvd player may support pal and can output it as ntsc for your tv.
If you want to convert to it to ntsc search for "pal to ntsc" for 8 millions different methods. Easiest is probaly ConvertXtoDVD, open the video_ts and choose ntsc and convert. You must rip it to the hd first with dvdfab decrypter. -
This isn't really the right forum for this question.
The Philips DVP-642, only one example of many, sells in the US for roughly $55 and if you enter the correct code on the remote control (see the DVD Players section or the DVD Hacks section on this site for the info - look at the columns on the left for the links) you will change it into a region free player. It can convert PAL DVD to NTSC output. If you buy a player that can convert, it is essential that you set the TV output to NTSC. By default, most converting DVD players set the TV output to something called "Multi" which is NOT what you want!
I don't recommend at all that you try to convert this DVD from PAL to NTSC. It's really not worth the effort and you'd be better off to just buy a DVD player that can convert PAL DVD to NTSC output so you can watch PAL DVDs in the future if you want.
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 21:59 -
PAL disc question...
By mjl1297 in forum Newbie / General discussionsReplies: 9Last Post: 7th Sep 2010, 15:43 -
Question about PAL quality on a USA DVD player and TV
By dancingcrab in forum Newbie / General discussionsReplies: 5Last Post: 10th Dec 2009, 12:39 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 09:53 -
Pal/Ntsc DVD Recorder question
By ArtieEngh in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 10:18
