hi i'm using Avi2dvd to convert a .ogg file with japnese and english.
but when i play it only the japanese seems to work. if i select english on my dvd player the screen just goes blue.
1 i load the .ogg into Avi2dvd
2 i select the first audio stream wich is japanese and choose ja
3 i do the same for english(en)
4 i select dvd-5 cause i'm using single layered dvds
5 i select QuEnc with 2 pass encoding but one try i used FreeEnc
6 i make my dvd menu with a start button an audio1(jap) and an audio2(en) button
7 i encode the dvd
8 i open nero express, and drag the files into the video_ts folder and burn
one thing i did notice is that my temp folder has all of the encoded files, but if i go up one directory, there are 2 audio files, one english and one japanese. can i put these into the audio_ts folder? will that fix my problem?
thanks
The audio_ts should be empty.
does the converted dvd work on your computer with a software dvdplayer? can you select the english audio track?
Good Languages vs. Bad Languages?
By hech54 in forum FeedbackReplies: 8Last Post: 17th Mar 2012, 14:56 -
Multiple audio languages and subtitle languages
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 15th Aug 2009, 13:44 -
mkv with 2 languages into PS3 compatible file using mkv2vob
By fairwind in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2009, 16:11 -
By fairwind in forum AudioReplies: 1Last Post: 22nd Jan 2009, 16:10 -
How can i combine 2 sub files (languages) into 1 sub file? (NOT cd1 & c
By Spixe in forum SubtitleReplies: 2Last Post: 4th Jun 2008, 09:33
