Video noob, but quick learner...
What is the best format/settings to optimize my video camera vids for youtube. YouTube mentions divx.
Do I start with MPEG-2 capture (through composite connection) then convert to DIVX then upload?
What converter and settings should I use to make my youTube vids sharp and crisp.
Thanks,
Kevin C
Results 1 to 11 of 11
You can upload the mpeg2 directly,
Here are our preferred video specs:
NTSC (4:3) size and framerate, deinterlaced
Video Codec: MPEG2 or MPEG4 (MPEG4 preferred)
Video Bitrate: at least 260Kbps (750kbps preferred)
Audio Codec: MP3 vbr
Audio Bitrate: at least 70Kbps (128 Kbps preferred)
but if it's huge it gonna take some hours to upload. Then you can reconvert to DivX, use for example autogk, use a low resolution like 320x240 if you source is interlaced to avoid interlace artifacts. -
YouTube uses RIVA FLV natively on their site. You can get the free encoder and player here:
http://www.rivavx.com/index.php?downloads&L=3
Scroll down and the last two apps are the ones you want
dang it. they don't seem to work on x64Originally Posted by Capmaster
Originally Posted by kcornwell
I never tried. It works OK on MPEG 1 & 2, though. Maybe you can convert it first?
I've got over 30 vids on YouTube. I've used both Xvid and RIVA FLV Encoder before uploading and neither produce consistant results. I've used DVD source material via Xvid that ended up crappy looking and SVCD quality source material run through RIVA turn out spectacular.
I just use RIVA now. -
thanks bro.Originally Posted by hech54
is everyone on this site always so helpful? love it! -
OopsOriginally Posted by kcornwell
I read it as "X264". Never mind ......
X.264 is an early MP4 codec. x64 is 64-bit Windows XPOriginally Posted by hech54
program to optimize for youtube
By Knightmessenger in forum Video Streaming DownloadingReplies: 46Last Post: 16th Nov 2011, 15:18 -
My videos are up on youtube, how do they look?
By fuzzblaster in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2010, 20:52 -
About youtube videos
By jackyshaikh in forum Video Streaming DownloadingReplies: 2Last Post: 15th May 2008, 12:57 -
YouTube Videos
By Jedi5 in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2008, 17:08 -
Youtube videos
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:05
