I can goto mpeg settings and set it vcd capture but there is not a svcd setting there is dvd ntsc setting and when I try to set everything manually then I still have problems with the stream being wrong and I cant set the size to 480X480 Another tquestion but it deals to this is even when Im capturing to ntsc vcd every time I have to goto capture pin setting and set the capture size.
