Hey im aly and i cannot hear sound on my winfast dv2000 (I am trying to watch the TV) can you help me
Yes i did check its not on mute!
Sound input via line-in
Check via sound icon in tray that line-in is not muted .
Speaker's out from speaker output .
You may also need to enter the setup of the program used to watch input , to check it is set to use line-in as audio input source , and not the input on the capture card .
Audio issue's can appear form , faulty cable connected to line-in , or fault in line-in socket (loose) or soundcard / onboard audio chipset .
Then on the other hand , you might have a fault with the connection on the playback device ... or cable .
Beware of these multi port switch device's ... some are made from cheap rubbish ... have pc showing the video , and at the same time , twist the audio connection's gently ... if you suddenly here audio , then you found the issue .
You would need one cable in "known working condition" to test if it's a cable issue .
Remember , these are stereo sockets on sound card , thats three pin's ... dont use 2 pin jacks ... they dont work .
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 12:13 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
Winfast PVR Interlace capturing, is it possible?
By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 21:46 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
