I bought one of these DVD players on Thanksgiving and it says it can play DivX. I was wondering if soft subs work on this player?
Edit:
While on the subject, how will DivX/DVD players like these treat overscan? Usually when I convert a video with hardsubs to DVD MPEG-2, I'd have to resize the video in a way so that the subs stay on the screen.
They work the same, just put the subs on the same disk as your avi & push the subtitle button to display. Should be covered iin the instruction book.
SRT subtitles generally are best, although a few other formats are supported. Your name looks Japanese and if you are expecting to be able to watch Divx with Japanese subtitles, you may have a problem. Some Philips models don't support external subtitles in anything except Latin and Cyrillic character sets. You'll have to check on your model.
My limited experience is that all Philips DVD players overscan. However, Divx subtitles will be visible unless your subtitle format allows you to specify screen locations, in which case it's up to you to be sure that they are correct. -
That's so cool for it to actually work!
I didn't want to open my package in case it doesn't work and I'd rather just refund it. But now I know. Thanks!
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
philips pet741
By mrt2001 in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2010, 11:02 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips DVP3040 Audio Trouble
By devilsknight in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2008, 16:52 -
Philips DVP3040 DivX playback jerky
By mkgordon in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jan 2008, 16:35
