I transfer using DV and keep the HUGE .AVI files in case wonder CODECs come out in the future.
In the meantime for sharing, I make MPEG2s using uLead software (not the greatest quality BTW). It creates files ending .MP2 as expected.
Today I switched to using the free "any video converter" and it creates mpeg2 files but names them .AVI
Why?
I have no idea why it would do that, but it seems a good reason not to use it. There are several other freeware encoding programs that would likely do a better job. Try HC for one or QuEnc. Or even SUPER if you need different format outputs.
EDIT: I did give Any Video Converter a try. I didn't have a DV file available at the time, so I ran an Xvid through. It converted OK to MPEG-2 with a new title of xxxmpeg2video.mpg from an original title of xxx.avi. Are you sure you have ''Hide extensions for known filetypes' unchecked in 'Tools>Folder Options>View'? Otherwise you aren't seeing the extension. The program seems to be about the same as SUPER. It uses several freeware tools to do the conversions.
Can't get video back to its original file version without the avi extension
By writersblck in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2012, 13:03 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
.PS to any video extension
By wazza88 in forum Video ConversionReplies: 3Last Post: 2nd May 2010, 20:56 -
.G64 (File Extension) to AVI / WMV
By Rhinestone in forum Video ConversionReplies: 3Last Post: 4th Oct 2009, 11:08 -
Extension .IMG
By Jomapil in forum ComputerReplies: 7Last Post: 17th May 2009, 08:52
