    Dec 2006
    Vietnam
    I downloaded a film which contains 2 file: 1 wmv and 1 subtitle file ( in type of .smi). How could I convert it into 1 wmv or avi file. I mean that when watching I only have to play 1 file included the sub. If it can be converted into 1 file, it is much easier to cut or to resize..etc..
    Thanks for helping me!!!
    Dec 2006
    Vietnam
    help me find out some way to convert...........
    Dec 2006
    Australia
    From what I've read, the program DIKO will do this, you add the avi and the subtitle file and it will convert to dvd or svcd format which you then burn.
