my my cd/dvd rom does not read any discs ( store bought, nor home backups).......winxp does recognize the drive, but for some reason neither cds nor dvds are being read. upon loading the tray with the disc, the led does blink.......and thats it.
thanks in advance for all comments.
Sounds like the drive might have died. Does it spin up when you put a disc in?
This same thing happened to my NEC 2510. The laser is out, time for a new drive.
Have you tried cleaning the laser lens with a cleaner disc?
1a.Go to Control Panel->System->Hardware->Device Manager->DVD/CD-ROM Drives and disable the drive.Reboot and enable it.
1b.In Device Manager->IDE ATA/ATAPI Controllers uninstall the secondary channel and reboot.
2.Use IsoBuster to see if it can read the discs.
3.Uninstall Nero InCD(if installed).
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
Any Way To Get XP To Read UDF2.60 Discs?
By Anakin in forum Authoring (DVD)Replies: 3Last Post: 13th Aug 2008, 19:52 -
LG RH1888H unable to read discs
By robin c in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Nov 2007, 10:48 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 07:03 -
Can any DVD drive read DVD DL discs?
By alegator in forum ComputerReplies: 3Last Post: 5th May 2007, 21:45
