Hi
I am trying to frameserve from VirtualDubMod to TMPGEnc. First, I select Direct Stream copy, and start frameserve... and save Temp.vri. But TMPGEnc couldn't open the temp.vri file. What have I done wrong ?
I think the problem is the name you gave the frameserved file - follow this guide and you should be all right.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Thanks. That helps. It turns out that I did not install the AVIFile frameclient support. Install the AVIFile frameclient support and it works.
possible to frameserve from Virtualdubmod to HCenc?
By spiritgumm in forum Video ConversionReplies: 104Last Post: 20th Mar 2010, 11:17 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 16:34 -
How to frameserve this resizing algorithm to TMPGEnc?
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 22:19 -
Frameserve from VirtualDubMod to TMPGEnc
By pchan in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 08:13
