newbie here, and i badly need help...
i have a dvd player, RCA - RC5215P, and i dont have the original remote control. i would like to unlock the region code but the guides i found need to push the "INFO" button on the remote. my problem now is that there's no "INFO" button on the universal remote im using.
can anyone help... please?
thanks and best regards.
Sounds like you will need an original remote or a universal with an info key (unless another key is used in place of the info key). Trial and error or the manual may tell you.
Also keep in mind that region codes don't always work. So even if you get the "info" key to work, doesn't mean the hack will work.Google is your Friend
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 10:24 -
Region Code Unlock for LG DR 4800 ?
By carletto in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Jul 2009, 11:04 -
Portland PVD 1000 DVD player Universal Remote code Needed
By richco in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Apr 2009, 16:17 -
Where to find universal remote code for Philips DVP5990/37?
By FredThompson in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Mar 2009, 10:14 -
DV-DS81E hitachi DVD recorder universal remote code needed
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jul 2007, 11:28
