I've read a lot of posts here about dvd recorders on hereand which one record the best quality
and have the best functions. So i've decided on either new or refurbished models:
JVC DR-M10
TOSHIBA D-R5
Both have a firewire. The Jvc does record lpcm audio in xp mode though.
Which do you think is the best?
I don't need a current model with a hard drive or vcr that I wont use. Thanks.
Results 1 to 13 of 13
I can offer a general opinion, not knowing the specific models. My philosophy of avoiding JVC products has served me well over the years. JVC tends to be cheaply made, IMO.
I'd go with the Toshiba
I have repaired and tested two JVC DR-M10S's. US versions of the M10 are prone to the "loading" bug where the front panel display starts to display the message "loading" after which the unit is locked up. The problem is caused by low drive levels between some integrated circuits which can be brought on by the power supply. The supply has two parts running at 94 degrees C. that cause premature aging of the parts.
The DR-MV1 ( combo unit ) and the non-US M10S units do not have this problem. The M10 has been replaced by the M100 which also does not seem to have this problem.
These two M10's ( one made in China, the other in Japan ) do not correctly reproduce NTSC IRE=7.5 black levels which are the black levels produced by US VHS and standard broadcast TV. The results of these tests can be found on this thread,
https://forum.videohelp.com/viewtopic.php?t=279460
M10S encoding is good, especially if you have tapes that are noisy. -
I ordered a JVC M10.
Im surprised Capmaster you dont like their products,
I thought they usually put out great products.
I hope I dont get the loading problem.
I ordered a refurbished model so it shouldn't be a problem.
Sounds like this machine is ideal for transferring vhs tapes if it helps with noisy pictures. -
As mentioned, the power supply/interface problems with this model only pertain the the US NTSC model. No other JVC model is affected. If you do get the loading problem, JVC will repair it. It is not considered a warranty repair. I have had a friend send in a 2004 unit for this problem and JVC repaired it two months ago without question. He was not the original owner either so they stand behind their product.
The only problem was that it took a month before it came back. -
How much did they charge you to repair it?Originally Posted by trhouse
Just my opinion. I've seen some of their product schematics, compared their circuit design guidelines with other brands, and decided they cut too many corners in years past.Originally Posted by deuce8pro
Their products have the bells and whistles, sure, but in the meat and potatoes of their designs, specifically component selections (like using a 5.5v alum. electrolytic capacitor in a 5v circuit instead of a 6 or 7-volt rated part), creating traces too close together on the PWB (arcing and solder bridging), leaving flux residue on the PWB (grows "stuff" in humid climates), etc. Just a lot of little things that led me to believe their #1 priority is profit and not product longevity.
But, like I said, it's just my opinion, for what it's worth
You might have good luck and make a liar out of me. I hope so
I somehow can not get this unit to record on taiyo yuden dvdrs. I put one in and press record and I get a cannot record error.
I hope its not a faulty unit. -
TY's good media. Have you tried any other media in it yet?
I had two M10S's which I repaired for the loading bug. Both were tested with TYG02 ( dvd-r, X8 disks ). They were flawless burns.
[edit]
The other media I tried with the M10S's were Panasonic dvd-ram X2-3, TDK dvd-rw X2, fake TYG02 disks ( dvd-r X8 ), and TDK dvd-rw X4. The only disks not recognized were the TDK dvd-rw X4's. -
If it s not too late, Dont buy Toshiba DR 5, they are filled with problems,
e mail me if you want all my opinion
TOTL S-VHS recorder suggestions
By raffie in forum RestorationReplies: 8Last Post: 17th Jul 2009, 13:37 -
Need some DVD Recorder suggestions, please!
By jeanpave in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Jan 2009, 14:52 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Looking for a new HDD DVD Recorder. Any suggestions?
By dagerousdave in forum DVD & Blu-ray RecordersReplies: 12Last Post: 2nd Dec 2008, 10:33 -
Looking to buy new dvd recorder, any suggestions?
By heman31 in forum DVD & Blu-ray RecordersReplies: 38Last Post: 16th Dec 2007, 19:17
