Hi there, I'm usin ffmpegx and i am trying to convert a divx avi to a DVD, but it only converts it to m2v. Am i missing a step? The tutorial at http://ffmpegx.com/dvd_sub.html says I should just run the conversion and then look for a VIDEO_TS folder... but it only creates a m2v file. I need the dvd for subtitles... as my dvd player can't read subs on a divx file (i think)
please help!!!!
Results 1 to 9 of 9
A M2V is just the video component of a MPEG-2 file. You will need the audio also. Since you are running OSX, you would get more answers in our Mac Forum. Moving you.
You might want to take a look to the upper left, for 'WHAT IS' DVD to see the DVD format and specifications, especially the components of the VIDEO_TS folder.
i see.... thanks... i learn quickly... but video is a big new world for me...
okay, so I finished the converstion and I ended up with a m2v file, an mpeg file an s.mpg file an xml file, and an ac3 file.
How do i translate these into DVD? -
That's strange as ffmpegX should give you a VIDEO_TS folder automagically.
Failing that, under the Tools section of ffmpegX, there is an option (somewhere - sorry not in front of my Mac right now) to author a DVD from an mpg file. Give that a go. Failing that, post your question in the ffmpegX forum here on Videohelp (or search for anyone having the same problem):
https://forum.videohelp.com/viewforum.php?f=35 -
i did it again with ffmpegx and played with the subtitle settings... I think it was because I was using the idx file? I'm not sure.... and with my computer it took all night... but this time it actually authored the VIDEO_TS file and 'lo and behol.d.. it worked (well now to test the burned DVD in my DVD player... cross my fingers)
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Avi to DvD .failed. "Cannot read .m2v ?
By ukel12 in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2008, 10:47 -
HELP! Encoding avi to m2v...
By iNDIGOarts in forum ffmpegX general discussionReplies: 2Last Post: 24th Nov 2008, 16:32 -
Huh? Weird board message never seen before
By DRP in forum FeedbackReplies: 2Last Post: 7th Apr 2008, 06:46 -
What? Macrovision hitch on firewire transfer from mini-DV to DVD? Huh?
By knowhow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 20th Feb 2008, 00:47
