My recorder has 2 inputs ( the one with the yellow, red and white cables -- what are that one called again?--)
but I have three things I need to record from.
What is the thing I can buy which could make this work. thanks.
The White and red are the audio. Yellow is the video. If the yellow one looks like the red and white ones, it called composite video. If the yellow one looks different, it's probably S-Video. Since you have three playback devices, you probably need something like this:
http://www.amazon.com/gp/product/B00008VSIQ/ref=pd_cp_e_title/103-1410417-7052617
This device can handle Composite video and S-Video.
Good luck! -
Thanks E.
that looks pretty good.
Unless someone knows better product, I may do it.
I guess it's called S video cable even if your are not using the "s" part, which is the black round thing right? for video.
I would be nice if you didn't even need select channel, if recorder could know automatically which unit the signal is coming from
PC to Plasma HD TV with DVI Input Question (Nvidia 8800GT Video Card).
By Infinite_Dreamz in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2011, 08:28 -
An AVStoDVD non-starter (file-system limitation)
By Seeker47 in forum Video ConversionReplies: 9Last Post: 24th Nov 2010, 10:53 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Is There A File Size Limitation to Convert .ts?
By toddon14th in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2008, 23:04 -
Lite on HD-A740GX input question/problem
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:32
